02-25-2004 09:17 AM - edited 03-09-2019 06:33 AM
I am trying to setup my 2514 with 12.2 IOS firewall.
What I want to do is use my E0 as local lan , and use E1 as DMZ. S0 being the interface connected to Internet and s1 connected to another router which will be our WAN connected to remote office.
the way it should be is how PIX firewall works.
that is any traffic from E0 going to E1, S0 and S1 should be permitted. Traffic coming back to E0 from any interface with the exception of S1 (WAN interface to remote office) should be denied.
Traffic from E1 (DMZ) should be permitted to go out to S0 (internet interface) and denied everywhere else. Traffic from S1 (Wan interface) should be permitted to E0 and E1 except S0.
Can someone help me with the access-list here..
Below is my unsuccesful attempt
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname NewYork
enable secret xxxx
enable password technology
ip subnet-zero
no ip source-route
ip inspect audit-trail
ip inspect udp idle-time 1800
ip inspect dns-timeout 7
ip inspect tcp idle-time 14400
ip inspect name standard cuseeme
ip inspect name standard ftp
ip inspect name standard h323
ip inspect name standard http
ip inspect name standard rcmd
ip inspect name standard realaudio
ip inspect name standard smtp
ip inspect name standard sqlnet
ip inspect name standard streamworks
ip inspect name standard tcp
ip inspect name standard tftp
ip inspect name standard udp
ip inspect name standard vdolive
interface Ethernet0
ip address 172.16.10.1 255.255.255.0
ip access-group 101 in
ip access-group 101 out
ip inspect standard in
no cdp enable
interface Ethernet1
ip address 172.16.20.1 255.255.255.0
ip access-group 111 in
ip inspect standard out
no cdp enable
interface Serial0
ip address 192.168.20.1 255.255.255.0
ip access-group 121 in
shutdown
no cdp enable
interface Serial1
ip address 192.168.10.1 255.255.255.0
ip access-group 131 in
ip access-group 102 out
shutdown
no cdp enable
ip classless
no ip http server
ip pim bidir-enable
logging 172.16.10.110
access-list 101 permit icmp 172.16.10.0
0.0.0.255 any
access-list 101 permit ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 101 deny ip 172.16.20.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 101 deny ip 192.168.20.0 0.0.0.255 172.16.10.0 0.0.0.
access-list 102 deny ip 172.16.20.0 0.0.0.255 192.168.10.0 0.0.0.255
access-list 102 permit ip any any
access-list 111 deny ip 172.16.20.0 0.0.0.255 172.16.10.0 0.0.0.255
access-list 111 deny ip 172.16.20.0 0.0.0.255 172.16.30.0 0.0.0.255
access-list 111 permit ip 172.16.20.0 0.0.0.255 any
access-list 111 permit icmp 172.16.20.0 0.0.0.255 any
access-list 111 deny ip any any
access-list 121 permit udp any host 172.16.20.3 eq domain access-list 121 permit tcp any host 172.16.20.3 eq domain access-list 121 permit tcp any host 172.16.20.3 eq www access-list 121 permit tcp any host 172.16.20.3 eq ftp access-list 121 permit tcp any host 172.16.20.3 eq ftp-data access-list 121 permit tcp any gt 1023 host 172.16.20.3 gt telnet access-list 121 permit tcp any host 172.16.20.3 eq smtp access-list 121 permit icmp any 172.16.20.0 0.0.0.255 administratively-prohibited access-list 121 permit icmp any 172.16.20.0 0.0.0.255 echo access-list 121 permit icmp any 172.16.20.0 0.0.0.255 echo-reply access-list 121 permit icmp any 172.16.20.0 0.0.0.255 packet-too-big access-list 121 permit icmp any 172.16.20.0 0.0.0.255 time-exceeded access-list 121 permit icmp any 172.16.20.0 0.0.0.255 traceroute access-list 121 permit icmp any 172.16.20.0 0.0.0.255 unreachable
access-list 121 deny ip any any
access-list 131 permit ip 192.168.10.0 0.0.0.255 172.16.10.0 0.0.0.255 access-list 131 permit ip 192.168.10.0 0.0.0.255 172.16.20.0 0.0.0.255
access-list 131 deny ip any any
no cdp run
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
02-26-2004 02:30 PM
HI,
E0 as Inside
E1 as DMZ1
S1 as DMZ2
S0 as outside.
from E0 to E1,S0 and S1, allowed
traffic from S1 to E0 allowd
Solution : apply inspect on E0
apply access-list on E1,S0 and S1 to block unwanted traffic
Traffic from E1 to S0 is allowd
Apply inspect on E1
apply access-list on E1 to block/permit traffic
Traffic from S1 to E0 and E1 allowd
apply access-list to only allow this traffic
Nadeem
