newoak (4001/tcp) vulnerability
marinos_g
I run nessus (port scanner) for a Cisco 2811 router and I don't understand one vulnerability from the results.
Here it is:
The remote system appears vulnerable to an invalid Options field
within a TCP packet. At least one vendor firewall (Symantec) has
been reported prone to such a bug. An attacker, utilizing this flaw,
would be able to remotely shut down the remote firewall (stopping all
network-based transactions) by sending a single packet to any port.
See also :
http://www.osvdb.org/displayvuln.php?osvdb_id=5596
http://www.eeye.com/html/Research/Advisories/AD20040423.html
Risk factor : High
CVE : CVE-2004-0444
BID : 10204, 10334, 10335
Other references : IAVA:2004-A-0010
Nessus ID : 12216
Is Cisco 2811 vulnerable to this bug?
Is there an IOS to fix this bug?
Symantec has released a patch to correct this bug.
Thank you for your help.
5 Replies 5
jwalker
Level 3
Level 3
I have not found anywhere in any of the documentation that Cisco products are susceptible to this vulnerability... All of the documentation I read indicates it only affects Symantec and Norton products.
Hi Jay,
Thank you for your reply.
To tell you the truth, when I posted my question, I didn't think I would get any reply at all :)
I see that you have some experience on security, also owner of CCSP, so you definitely know more about this.
Well, I couldn't find any documents for Cisco products about this vulnerability either, but I need to be sure.
Do you think if I open a TAC case they can help me?
Thank you
Marinos
Can you please post the IOS version you are running on your router - output the content of "sho ver" here and we can confirm if the vulnerability is related to your specific platform.
But personaly, I've not come across this on the 2800 platform. Of course you can open up a TAC case on this too.
Thanks / Jay
Here it is:
Cisco IOS Software, 2800 Software (C2800NM-SPSERVICESK9-M), Version 12.4(4)T, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 27-Oct-05 11:24 by ccai
ROM: System Bootstrap, Version 12.3(8r)T7, RELEASE SOFTWARE (fc1)
2811_Gateway1 uptime is 3 weeks, 2 days, 20 hours, 11 minutes
System returned to ROM by reload at 15:04:12 GTB Fri Aug 4 2006
System restarted at 15:05:20 GTB Fri Aug 4 2006
System image file is "flash:c2800nm-spservicesk9-mz.124-4.T.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 251904K/10240K bytes of memory.
Processor board ID FCZ0946707C
2 FastEthernet interfaces
31 Serial interfaces
1 ISDN Basic Rate interface
1 Channelized E1/PRI port
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
62720K bytes of ATA CompactFlash (Read/Write)
This is due to 'transport input telnet' on the AUX port. To disable, do:
line aux 0
 no transport input
