IOS 12.4T: no radius accounting when redundancy inter-device is configured
Even the redundancy protocol is not configured with any profile, the effect of having redundancy inter-device configured as a config parameter end in suppressed radius requests. Can be verified with debug aaa accounting
*Jan 11 23:21:37.475: AAA/ACCT(00000003): Accouting method=CRYPTO-ACS-NEW (RADIUS)
*Jan 11 23:21:37.475: AAA/ACCT/EXEC(00000003): Suppressed record
The command can not be removed with the "no" option. Config must be manually modfied and copied to start-up.
TEST-FSI-3825#sho radius stat
Auth. Acct. Both
Maximum inQ length: NA NA 0
Maximum waitQ length: NA NA 0
Maximum doneQ length: NA NA 0
Total responses seen: 0 0 0
Packets with responses: 0 0 0
Packets without responses: 0 0 0
Access Rejects : 0
Average response delay(ms): 0 0 0
Maximum response delay(ms): 0 0 0
Number of Radius timeouts: 0 0 0
Duplicate ID detects: 0 0 0
Buffer Allocation Failures: 0 0 0
Maximum Buffer Size (bytes): 0 0 0
Malformed Responses : 0 0 0
Bad Authenticators : 0 0 0
Unknown Responses : 0 0 0
