MACSec across WAN/MAN
Mark Williams
Hi.
Has anyone had any experience with configuring MACSec between two routers/switches that are the end points of a WAN/MAN circuit?
We plan on using two 3750-X as the routers on a circuit that is 1Gb/s EoSDH.
The thing I am worried about is that the carrier will not be able to transport the frames.
So.. is there anything I need to consider when using MACSec on WAN/MAN circuits?
Especially for EoSDH and L2 MPLS VPNs type links.
Aaron D
Did you ever find a solution to this issue? We are also trying to implement MACSEC over SDH and though the carrier says we shouldn't have any issues we cannot get it to function.
Thanks-
