NTP problem on IDS sensor
dennis.foon
May I have to ask how can sensor (4235, OS v4.1) configure NTP setting? The NTP authentication seemed to be required and also mandatory, but the problem is our client hasn't this implementation on their Global NTP server. Any suggestion? Thanks.
Dennis.
jamesand
Yes, the NTP server key val/id fields are required. Also, the only officially supported NTP server (right now) is a cisco router.
Thanks, James.
I'll follow your information.
Dennis.
