08-26-2003 08:00 PM - edited 03-09-2019 04:34 AM
May I have to ask how can sensor (4235, OS v4.1) configure NTP setting? The NTP authentication seemed to be required and also mandatory, but the problem is our client hasn't this implementation on their Global NTP server. Any suggestion? Thanks.
Dennis.
08-27-2003 07:55 AM
Yes, the NTP server key val/id fields are required. Also, the only officially supported NTP server (right now) is a cisco router.
08-27-2003 09:24 AM
Thanks, James.
I'll follow your information.
Dennis.
