Object Group Help
eelliston
I have 3 full class C address spaces that I need to define in an access list. Most of them will have www,SSL,FTP ...
Is there a way I can either use the object group or define a range of addresses..
for instance:
I want WWW,80,SSL,FTP on the addresses 216.82.64.61 - 216.82.65.99
How can I do this without typing everything in?
Thanks!
No problem. And Yes, we can also handle your other request. Just add the following configuration (assuming inside/outside interface but this can change as needed):
static (inside,outside) 216.82.0.0 192.168.0.0 255.255.0.0
With this command in place, the PIX will replace the "192.168" with "216.82" on any packets traversing the interfaces in question. The last 2 octets will be unchanged.
Is this what you were looking for?
Scott
scoclayton
Level 7
Level 7
I am pretty sure this will do the trick. Hopefully, my subnetting skills are still sharp. You may want to make sure that the network and broadcast addresses from the subnets I put below get added to the access-list. If they do not, you may need to add specific "network-object host" statements for 216.82.64.64, 216.82.64.127, 216.82.64.128, etc...
object-group network servers
network-object host 216.82.64.61
network-object host 216.82.64.62
network-object host 216.82.64.63
network-object 216.82.64.64 255.255.255.192
network-object 216.82.64.128 255.255.255.128
network-object 216.82.65.0 255.255.255.192
network-object 216.82.65.64 255.255.255.224
network-object host 216.82.65.96
network-object host 216.82.65.97
network-object host 216.82.65.98
network-object host 216.82.65.99
access-list 101 permit tcp any object-group servers eq 80
access-list 101 permit tcp any object-group servers eq 443
access-list 101 permit tcp any object-group servers eq 21
Hope this helps.
Scott
I love this place =)
Is there a way I can use the same method when setting up one to one NAT?
Every address is going to be associated with an private IP. Everything except the first 2 octets will be the same IE. 216.82.65.64 = 192.168.65.64
I have it already made, but the static statements are HUGE. is there a way I can clean it up?
Thanks again! Big help...
Scott
