12-21-2004 03:56 AM - edited 03-09-2019 09:49 AM
I left an 837 on site with a view to configuring it later. Now I am back at the office I want to configure it. When I telnet in, it asks me for username and password. Anyone know what the defaults are for an 837
12-21-2004 04:53 AM
Taken from the 837 Config guide:
By default, the router ships without password protection. Because many privileged EXEC commands are used to set operating parameters, you should password-protect these commands to prevent unauthorized use.
Is this a new router?
Rgds
PD
12-21-2004 05:04 AM
well new (ish). I put a config on, but then reset it. I have tried the original security that I put on it, but it doesn't work.
12-21-2004 05:17 AM
Did you use the web browser interface to configure the router?
Could the following link apply to you?
http://www.cisco.com/en/US/products/hw/routers/ps380/products_field_notice09186a00800e9476.shtml
Rgds
PD
12-21-2004 05:46 AM
you need to set the telnet password before you can use telnet.
looks like you will have to go back on site. there is no default password.
rob
12-21-2004 06:32 AM
I think I have worked it out. Got in via a server and the web access. The telnet option is not enabled by default. Thanks for you help. ;0)
