Observing vulnerability in WLC(AIR-CT5508-K9)
csawest.dc
Level 3
Level 3
HI All,
We are observing below vulnerability in WLC(AIR-CT5508-K9)
Product Version : 8.2.151.0
TLS/SSL Server Does Not Support Any Strong Cipher Algorithms
Weak Cryptographic Key
TLS/SSL Server Supports The Use of Static Key Ciphers
Self-signed TLS/SSL certificate
Untrusted TLS/SSL server X.509 certificate
SHA-1-based Signature in TLS/SSL Server X.509 Certificate
X.509 Certificate Subject CN Does Not Match the Entity Name
Please suggest . Thanks !!
There is still something you could do here:
  1. Upgrade to a more recent version
  2. disable legacy crypto: "config network secureweb cipher-option high enable"
  3. Replace the certificate with a correct and trusted one.
But as always, be aware of the consequences (at least with "2.") ...
Leo Laohoo
Go HERE.
HI Team,
Anyone could help me on this?
We are Also observing below vulnerability in WLC(AIR-CT2504-K9)
Product Version : 8.5.160.0
Appreciate your prompt response. TIA!
Abdullatif
can you help on how to fix this vulnerability on cisco WLC "Weak Cryptographic Key" .
