OpenSSH Vulnerabilities in Cisco C9200L and C9300 switches
itsu
Hi folks,
Our vulnerability scanning tool has picked up couple of OpenSSH related vulnerability in all our 9000 series switch. See attached screenshot.
I checked for any related post online but I couldn't find anything, even though there are some related, they are from different cisco products.
So far, I have applied the following configs below I came across online but that hasn't fix the problem. After I ran the remediation scan I can see that the vulnerabilities are still there.
DR-CORE-SW-STACK#configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
DR-CORE-SW-STACK(config)#crypto key generate rsa modulus 4096 label my-4096rsa-ssh-key
% You already have RSA keys defined named my-4096rsa-ssh-key.
% They will be replaced.
% The key modulus size is 4096 bits
% Generating 4096 bit RSA keys, keys will be non-exportable...
[OK] (elapsed time was 2 seconds)
DR-CORE-SW-STACK(config)#ip ssh rsa keypair-name my-4096rsa-ssh-key
DR-CORE-SW-STACK(config)#ip ssh version 2
DR-CORE-SW-STACK(config)#ip ssh server algorithm authentication keyboard
DR-CORE-SW-STACK(config)#ip ssh server algorithm kex ecdh-sha2-nistp521 ecdh-sha2-nistp384
DR-CORE-SW-STACK(config)#ip ssh server algorithm hostkey rsa-sha2-512 rsa-sha2-256
DR-CORE-SW-STACK(config)#ip ssh server algorithm encryption aes256-gcm aes256-ctr
DR-CORE-SW-STACK(config)#ip ssh server algorithm mac hmac-sha2-512 hmac-sha2-256
DR-CORE-SW-STACK(config)#ip ssh server algorithm publickey ecdsa-sha2-nistp521 ecdsa-sha2-nistp384
DR-CORE-SW-STACK(config)#do wri
Building configuration...
[OK]
How can I remove these vulnerabilities, any good folks want to help?
I really appreciate your help on this.
Thank you,
6 Replies 6
 Are you sure the scanning was ran against a Cisco switch, I dont recall cisco device using OpenSSH
On the link below there are planty of tips related to strong SSH, hope that can help you
https://community.cisco.com/t5/networking-knowledge-base/configuring-ios-xe-for-strong-security-ssh-sessions/ta-p/4556490
Hi Flavio,
I did came across this site and use the configs above however, the issue still persist when I ran the scan.
Hello Kevin,
I do not see any SSH related vulnerability in your configuration. It looks good.
I am also using same configuration. What version you are using in Switch?
C9300-01#sh ip ssh
SSH Enabled - version 2.0
Authentication methods:keyboard-interactive
Authentication Publickey Algorithms:ecdsa-sha2-nistp256,ecdsa-sha2-nistp384
Hostkey Algorithms:rsa-sha2-512,rsa-sha2-256
Encryption Algorithms:aes256-ctr
MAC Algorithms:hmac-sha2-256,hmac-sha2-512
KEX Algorithms:ecdh-sha2-nistp521
Authentication timeout: 60 secs; Authentication retries: 5
Minimum expected Diffie Hellman key size : 2048 bits
IOS Keys in SECSH format(ssh-rsa, base64 encoded): TP-self-signed-2962435495
Modulus Size : 2048 bits
I'm wondering if your acan is not sending out common vulnerability for SSH and not actually seing it on the Switch because it show OpenSSH which I dont believe Cisco use it.
 Is this an oficial scan tool or some free software?
please share
show ip ssh
I think there are other cipher use by default
MHM
Leo Laohoo
IOS-XE only is affected by regreSSion vulnernability if the platform has NETCONF enabled AND running vulnerable version (fixed from 17.15.1).
If NETCONF is not enabled, the IOS-XE is not affected.
