Showing results forĀ
Search instead forĀ
Did you mean:Ā
Option missing from side menu in ACS 5.8.1.4 for TLS
david-imrie
Hi all,
I'm trying to up the TLS version used in ACS (yes i know it's obsolete) as its still using TLS 1.0
Show ver confirms im running ACS 5.8.1.4
All instructions online say Newer TLS should be on by default, and can be edited via:
System Administration > Configuration > Global System Options > Security Settings.
But i cant see that option.. Any ideas.
balaji.bandi
As far as I'm aware yes.. I assume the 4 in 5.8.1.4 means patch 4? it also seems to be the last release as far as i can tell.
There's an additional patch file you need to apply that will provide you with the menu for Security Settings. File name is "5-8-0-32-10.tar.gpg". After applying the patch and rebooting my ACS instance, I was able to see the menu option.
Edit: Forgot to link the release notes for this patch to indicate it is for version 5.8.1.4. https://www.cisco.com/web/software/282766937/128831/Acs-58Patch10-Readme.txt
