oracle conserns
darin.marais
Level 4
Level 4
My client is concerned about the following cert realease to the press. Is there any way to check if Cisco have responded to the suspected vulnerability with a signature and if so what is the id of the signature.
http://www.us-cert.gov/cas/techalerts/TA04-245A.html
jkanclirz
You can check the online IDS signature database and the NSDB (network security database).
http://www.cisco.com/cgi-bin/front.x/csec/idsHome.pl
http://www.cisco.com/go/csec/
(note: will need CCO account to view detail sig)
I've looked but could not find any for the latest Oracle vulnerabilities. Contact your Cisco Rep!
You could also view snort.org signatures to help you write your own for Cisco IDS.
* 2599 - ORACLE add_grouped_column named sname/oname buffer overflow attempt
* 2600 - ORACLE add_grouped_column ordered sname/oname buffer overflow attempt
* 2601 - ORACLE drop_master_repgroup named gname buffer overflow attempt
* 2602 - ORACLE drop_master_repgroup ordered gname buffer overflow attempt
* 2603 - ORACLE create_mview_repgroup named fname buffer overflow attempt
* 2604 - ORACLE create_mview_repgroup ordered fname buffer overflow attempt
* 2605 - ORACLE compare_old_values ordered sname/oname buffer overflow attempt
* 2606 - ORACLE comment_on_repobject named type buffer overflow attempt
* 2607 - ORACLE comment_on_repobject ordered type buffer overflow attempt
* 2608 - ORACLE check_ddl_text ordered buffer overflow attempt
* 2609 - ORACLE cancel_statistics named sname/oname buffer overflow attempt
* 2610 - ORACLE cancel_statistics ordered sname/oname buffer overflow attempt
* 2611 - ORACLE LINK metadata buffer overflow attempt
* 2612 - ORACLE revoke_surrogate_repcat named userid buffer overflow attempt
* 2613 - ORACLE revoke_surrogate_repcat ordered userid buffer overflow attempt
* 2614 - ORACLE time_zone buffer overflow attempt
* 2615 - ORACLE grant_surrogate_repcat named userid buffer overflow attempt
* 2616 - ORACLE grant_surrogate_repcat ordered userid buffer overflow attempt
* 2617 - ORACLE alter_mview_propagation named gname buffer overflow attempt
* 2618 - ORACLE alter_mview_propagation ordered gname buffer overflow attempt
* 2619 - ORACLE alter_master_repobject named type buffer overflow attempt
* 2620 - ORACLE alter_master_repobject ordered type buffer overflow attempt
* 2621 - ORACLE utl.register_flavor_change ordered buffer overflow attempt
* 2622 - ORACLE utl.drop_an_object ordered buffer overflow attempt
* 2623 - ORACLE utl.create_snapshot_repgroup ordered buffer overflow attempt
* 2624 - ORACLE unregister_user_repgroup named privilege_type buffer overflow attempt
* 2625 - ORACLE unregister_user_repgroup ordered privilege_type buffer overflow attempt
* 2626 - ORACLE send_old_values ordered sname/oname buffer overflow attempt
* 2627 - ORACLE repcat_import_check named gowner/gname buffer overflow attempt
* 2628 - ORACLE repcat_import_check ordered gowner/gname buffer overflow attempt
* 2629 - ORACLE register_user_repgroup named privilege_type buffer overflow attempt
* 2630 - ORACLE register_user_repgroup ordered privilege_type buffer overflow attempt
* 2631 - ORACLE refresh_mview_repgroup named gowner buffer overflow attempt
* 2632 - ORACLE refresh_mview_repgroup ordered gowner buffer overflow attempt
* 2633 - ORACLE rectifier_diff named sname1 attempt
* 2634 - ORACLE rectifier_diff ordered sname1 buffer overflow attempt
* 2635 - ORACLE snapshot.end_load named gname buffer overflow attempt
* 2636 - ORACLE snapshot.end_load ordered gname buffer overflow attempt
* 2637 - ORACLE drop_master_repobject named type buffer overflow attempt
* 2638 - ORACLE drop_master_repobject ordered type buffer overflow attempt
* 2639 - ORACLE drop_mview_repgroup named gowner buffer overflow attempt
* 2640 - ORACLE drop_mview_repgroup ordered gowner/gname buffer overflow attempt
* 2641 - ORACLE drop_site_instantiate named refresh_template_name buffer overflow attempt
* 2642 - ORACLE drop_site_instantiate ordered refresh_template_name buffer overflow attempt
* 2643 - ORACLE ensure_not_published ordered fname buffer overflow attempt
* 2644 - ORACLE from_tz buffer overflow attempt
* 2645 - ORACLE instantiate_offline named refresh_template_name buffer overflow attempt
* 2646 - ORACLE instantiate_offline ordered
...continue
