password recovery for 2610
sandhu2211
Ttried with cisco method but after doing reset it comes back to rommon 1>. used confreg 0*2142 and then reset but it goes back to rommon 1>. If i boot using boot flash:<filename> it again asks for the password. Plz Help
sachinraja
Level 9
Level 9
Hello Satinder
Looks like your IOS code is working good.. when you do confreg 0x2142 on your router and reset the router, dont you get the initial configuration wizard  ? can you send us the exact outputs of the router bootup after you reset the router with 0x2142 ? There are other config register values to put your router on rommon, but none of them ignores the content of NVRAM , as does the 2142 ...
Raj
