PCs flooding broadcast addr. udp port 137/138
neonetsup
Hi all,
Interesting problem: Our 6509 switch connects a LAN via routed port/interface. Netflow was turned on that particular interface and 82% of the total flows are "UDP-other" with source and destination ports of udp 137 and 138.
The "heavy hitters" of this group are about 6 PCs and the destination IP is the broadcast address of the network.
Virus? Misconfigured Windows machines?
Thanks for any ideas!
Kevin Dorrell
Level 10
Level 10
It's pretty normal to have quite a lot of directed broadcast traffic to UDP/135-139. But if there are some particularly hard hitters, they would be worth investigating. The favorite ports for worms are 137, 138, and 445. Look out for scans on UDP/445.
Kevin Dorrell
Luxembourg
Patrick Iseli
Level 7
Level 7
This are netbios broadcast on hosts that have probably no WINS configured (win2K) od DNS with Activ Adirectory (MS AD = MAD).
Each time a hosts connects to a printer or share it does a broadcast to find it.
NetLogon UDP:138
Logon Sequence UDP:137,138 TCP:139
Pass Through Validation UDP:137,138 TCP:139
Printing UDP:137,138 TCP:139
Trusts UDP:137,138 TCP:139
WinNT Secure Channel UDP:137,138 TCP:139
Do a " ipconfig /all" on that host a see if you are hybrid mode = WINS
broadcast = Broadcast = thats bad
sincerely
Patrick
