pdm - tcp port 443
moran.wolfman
Does somebody know about a tcp port called "pdm" (port number 443)?
Is it supported by Cisco ASA?
In what version?
maik.behley
Hi, this is the device manager from the older model called cisco pix. The pdm stands for Pix Device Manager. If you want to manage the asa you must use the asdm (adaptive security device manager).
http://www.cisco.com/go/asdm/
You need port number 443/tcp for this.
Kind regards.
Maik Behley
Marvin Rhoads
Maik got it right. The pix (which became the ASA ) management GUI was PDM. The current equivalent is ASDM and either way they use tcp/443 https.
