Phatbot Trojan/Worm Detection
derwalke
This trojan / worm was discovered on the 15th and has a high exploitation potential. Its details are summarized and our coverage is outlined here:
http://www.cisco.com/cgi-bin/front.x/csec/view.pl?VID=3913
Derek
rmulyadi
I am trying to convert this two snort signature into cisco ids sigs. since this is my first time using the custom signature function, can someone helps me out here, especially the regular expression part?
Snort Sig 1.
alert tcp any any -> any any (msg:"Agobot/Phatbot Infection
Successful"; flow:established; content:"221 Goodbye, have a good
infection |3a 29 2e 0d 0a|"; dsize:40; classtype:trojan-activity;
reference:url,www.lurhq.com/phatbot.html; sid:1000075; rev:1;)
Cisco Sig 1.
SIGID: 20006
SubSig: 0 default: 0
AlarmDelayTimer:
AlarmInterval:
AlarmSeverity: medium default: medium
AlarmThrottle: Summarize
AlarmTraits:
CapturePacket: True default: False
ChokeThreshold:
Direction: ToService default: ToService
Enabled: True
EndMatchOffset:
EventAction:
FlipAddr:
MaxInspectLength: 40
MaxTTL:
MinHits: 1
MinMatchLength:
Protocol: TCP default: TCP
RegexString: 221 Goodbye\, have a good infection
ResetAfterIdle: 15
ServicePorts: 0-65535
SigComment:
SigName: Agobot/Phatbot Infection Successful default: STRING.TCP
SigStringInfo:
SigVersion:
StorageKey: STREAM
StripTelnetOptions:
SummaryKey: Axxx
ThrottleInterval: 15
WantFrag:
Snort Sig 2:
alert tcp any any -> any any (msg:"Phatbot P2P Control Connection";
flow:established; content:"Wonk-"; content:"|00|#waste|00|"; within:15;
classtype:trojan-activity; reference:url,www.lurhq.com/phatbot.html;
sid:1000076; rev:1;)
Cisco Sig 2.
SIGID: 20007
SubSig: 1 default: 0
AlarmDelayTimer:
AlarmInterval:
AlarmTraits:
ChokeThreshold:
Enabled: True
EndMatchOffset:
EventAction:
FlipAddr:
MaxInspectLength:
MaxTTL:
MinHits: 1
MinMatchLength:
Protocol: TCP
RegexString: Wonk-.*waste
ResetAfterIdle: 15
SigComment:
SigName: Phatbot P2P Control Connection default: STRING.TCP
SigStringInfo:
SigVersion:
StorageKey: STREAM
StripTelnetOptions:
SummaryKey: Axxx
WantFrag:
Here is a translation of the regexes that should work:
1)
content:"221 Goodbye, have a good infection |3a 29 2e 0d 0a|"
221 Goodbye,[ ]have a good[ ]infection[ ]\x3a\x29\x2e\x0d\x0a
2)
Wonk-.*\x00[#]waste\x00
Note: A word of caution about the ServicePorts parameters. Setting them to all TCP ports like the Snort signature is likely to cause a fairly negative performance impact on your sensor. One possible way to lessen the impact would be to use the ATOMIC.TCP engine instead of STRING.TCP. Just substitute the SinglePacketRegex parameter for RegexString, and set the following:
TcpFlags PSH|ACK
Mask ACK
This causes alittle less overhead in your signatures, but it is also going to cause a significant load on your sensor. It is best to limit the port range if you can.
I just tried it, but it seems to crash the sensor. It has been processing the config for more than 2 hours.
