Pix520 to 5002 connection
kcopping
Having problems connecting more than 1 client to a 5002 Concentrator using a PAT address on a Pix520. The client has NAT Transparency Mode turned on. Even if I create a static translation I cannot get more than 1 client to connect and pass traffic. I was able to get it to work on a 7206 with some slight tweeking on the NAT timeouts. Any help would be great.
wdrootz
Level 4
Level 4
You might want to check with Cisco to make sure that’s a supported configuration first. I couldn’t find anything online.
rak_shah
please refer to the bugid CSCdt23585 and CSCds40796. These are i think similar to your case.
regds
