Placing of IPS Device
ramkunta
In a scenario, there are Two firewalls that are connected to two core switches, I want to place IPS sensor inline with Firewall and core switch, but I have only One IPS.Can i connect in this way? Or is it mandatory to have two IPS?
Nicolas Fournier
Hi Rama,
With virtual sensors, you can put multiple IPS on your network even though you only have a single physical device.
for more info on virtual sesnsors:
http://www.cisco.com/en/US/docs/security/ips/6.2/configuration/guide/cli/cli_virtual_sensors.html
I think that it might help in your design.
Nicolas
