Policy Maps & Class Maps in 9.2.x
Andrew Meyer
Beginner
Beginner
I recently upgraded to 9.2.1 on my ASA 5505.  I had been recording the configs and matching them.  I noticed that with the latest ASA code the policy maps are no longer in the default config??  Or at least that had been removed when I upgraded to 9.2.1.  Maybe i'm missing something or I did something.
David Castro F.
Participant
Participant
if you run a "more system:running-config" command, you should be able to see the MPF configuration at the bottom, let me know how it works out!
Please proceed to rate and mark as correct the helpful post! Kep mee posted
David Castro,
