Port Redirection - internal two links
jcoykendall
Here is my setup:
Internet
T1
Cisco 2610
12.xxx.xxx.1
12.xxx.xxx.2
Cisco PIX 506E
172.16.80.60
172.16.80.1
Cisco 2610 - - Remote Site
T1
172.16.16.1
Cisco 3600 - - Central Site
172.16.16.10
Web Server
What I'd like to do is house the webserver at our central site (172.16.16.x) but access it from a global address from the remote site (172.16.80.x/12.x.x.x), I will be doing this in case our primary connection is loss at our central site.
Snipped config
access-list outside_access_in permit tcp any host 12.xxx.xxx.xxx eq 80
static (inside, outside) tcp 12.xxx.xxx.xxx 80 172.16.16.10 80 netmask 255.255.255.255 0 0
And this is from xlate debug (timeout):
TCP PAT from inside:172.16.16.10/80 to outside:12.xxx.xxx.xxx/80 flags sri idle 0:00:10 timeout 0:00:30
I tried this on a web server on the remote site, but I'd to ultimately have the traffic routed to our Primary site...
TIA for your help !!
6 Replies 6
jmia
Level 7
Level 7
Hi -
Don't know if you've checked this document:
http://www.cisco.com/warp/public/707/28.html
Hope this helps -
Yes, in reference to topic #9
"Port Redirection with Statistics"
I was able to hit the web server if static was configured for that location...
Cheers.
jmia
Level 7
Level 7
Hi -
Forgot to mention, did you do cmd 'clear xlate' after you implemented the static and ACL ?
Jay
Yes.. I had cleared the xlate, and here is a latest snip from "show xlate debug"
NAT from inside:172.16.16.10/80 to outside:12.xxx.xxx.xxx/80 flags sri idle 0:17:47 timeout 3:00:00
If this helps at all.
Is it possible for you to post your PIX config, either here or direct to me (email above).
PLEASE REMEMBER TO CHANGE REAL IP's AND PASSWORD(S)
Thanks -
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxxxxxxxxxxxxxxxxx
passwd xxxxxxxxxxxxxxxxxxxx encrypted
hostname remote-gw
domain-name remote.org
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
name 172.16.80.0 Remote
name 172.16.16.0 Central
access-list inside_access permit tcp any any eq www
access-list inside_access permit tcp any any eq https
access-list inside_access permit tcp any any eq domain
access-list inside_access permit icmp any any echo-reply
access-list outside_access permit icmp any any
access-list outside_access permit tcp any host 12.xxx.xxx.xxx eq www
pager lines 24
logging on
logging timestamp
logging trap notifications
logging host inside 172.16.xxx.xxx
icmp permit any outside
icmp permit any inside
mtu outside 1500
mtu inside 1500
ip address outside 12.xxx.xxx.xxx 255.255.255.224
ip address inside 172.16.xxx.xxx 255.255.240.0
ip verify reverse-path interface outside
ip verify reverse-path interface inside
ip audit name attack attack action alarm drop
ip audit name ids info action alarm
ip audit interface outside ids
ip audit interface outside attack
ip audit interface inside ids
ip audit interface inside attack
ip audit info action alarm
ip audit attack action alarm drop
pdm logging alerts 100
pdm history enable
arp timeout 14400
global (outside) 1 12.xxx.xxx.xxx-12.xxx.xxx.xxx netmask 255.255.255.224
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 12.xxx.xxx.xxx 172.16.16.10 netmask 255.255.255.255 0 0
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
route outside 0.0.0.0 0.0.0.0 12.xxx.xxx.xxx 1
route inside 172.16.0.0 255.255.0.0 172.16.80.1 1
route inside 172.16.16.0 255.255.240.0 172.16.80.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
floodguard enable
console timeout 0
terminal width 80
