01-03-2003 09:00 AM - edited 03-09-2019 01:33 AM
I want to use a 1710 for a GRE end-point. The DSL provider requires PPPoE authentication. Is there any sample configs that show how to have a 1710 authenticate to a Westel Modem (configured as a bidge) and use the bridges IP (static)? I can do the vpn stuff, I just have never doen pppoe stuff.
Solved! Go to Solution.
01-06-2003 07:06 AM
I could not find any examples of connecting to a Westel Modem but the following link has several examples of configuring PPPoE on the 1710. http://www.cisco.com/warp/public/794/index.shtml
01-06-2003 07:06 AM
03-13-2003 05:06 PM
If you still need help. Drop me a not and I will send you a sample config.
07-20-2003 01:14 AM
Hi Jroy,
I'm interested om your sample config,can you post it out as I current;y working on almost the same
config.
thks
