01-05-2005 01:45 PM - edited 03-09-2019 09:55 AM
Does anybody know what the maximum pps the pix535 can handle?
01-05-2005 02:06 PM
The last note in the Quick Reference Guide from april 2003 says 1.7Gbps.
PIX 535 Carrier class large enterprise and service provider firewall appliance
Up to 1.7 Gbps of firewall throughput1
Up to 440 Mbps of 3DES/AES-256 VPN throughput using hardware acceleration (integrated in select
models, optional for others)
VPN concentrator services (Easy VPN Server) for up to 2,000 remote users
Gigabit Ethernet throughput; Up to ten 10/100 FE or nine Gigabit Ethernet interfaces
VLAN trunking (802.1q tag-based) and OSPF dynamic routing support
Redundant, hot-swappable power supplies
Active/standby stateful failover support
But that might be higher by now.
sincerely
Patrick
01-05-2005 04:11 PM
Thank you for the response, but I already read the link you got that from. There is nothing about Maximum PPS on the performance. Am I missing something?
Charles
