PPS for PIX535
cconte
Does anybody know what the maximum pps the pix535 can handle?
Patrick Iseli
Level 7
Level 7
The last note in the Quick Reference Guide from april 2003 says 1.7Gbps.
PIX 535 • Carrier class large enterprise and service provider firewall appliance
• Up to 1.7 Gbps of firewall throughput1
• Up to 440 Mbps of 3DES/AES-256 VPN throughput using hardware acceleration (integrated in select
models, optional for others)
• VPN concentrator services (Easy VPN Server) for up to 2,000 remote users
• Gigabit Ethernet throughput; Up to ten 10/100 FE or nine Gigabit Ethernet interfaces
• VLAN trunking (802.1q tag-based) and OSPF dynamic routing support
• Redundant, hot-swappable power supplies
• Active/standby stateful failover support
But that might be higher by now.
sincerely
Patrick
cconte
Thank you for the response, but I already read the link you got that from. There is nothing about Maximum PPS on the performance. Am I missing something?
Charles
