05-22-2008 10:31 AM - edited 03-09-2019 08:46 PM
I am currently using a CiscoSecure ACS server to authenticate PPTP clients to a VPN 3000. The documentation states you enable PPTP by editing the Base Group on the VPN 3000. But I want to use separate IP address ranges for different users to apply ACLs, but I cannot figure out how to assign users on the ACS server to a different group that points to a group other than the base group on the VPN 3000.
05-23-2008 01:49 AM
Armand,
The below is a good guide
HTH.
05-29-2008 10:31 AM
The guide helped, but was incomplete. With the help of TAC we figured it out. In order for CiscoSecure ACS to point to a different group on the VPN 3000 Concentrator, you have to enable RADIUS IETF attribute #25 and specify the group name on the concentrator. What was lacking from the guide was the exact syntax. The correct syntax was "ou=groupname" and it worked.
