Problem connect with SSH to outside interface of Admin Context
forwardslash
Try to connect to the outside interface of the Admin context using SSH even try ASDM with no luck
Get the following with sh conn
TCP out 10.101.0.89:61845 in 192.168.2.3:23 idle 0:00:05 Bytes 18 FLAGS - Bs
Patrick Laidlaw
Level 4
Level 4
Do you have the statement
ssh x.x.x.x 255.255.255.255.0 outside
Which allows ssh to the outside interface from the ip range you want. You'll have to do the same for http.
Patrick
Please rate any posts that were helpful.
I've got the following inf the admin context config
ssh 10.101.0.88 255.255.255.255 outside
ssh timeout 30
I've added for ASDM
http server enable
http 10.101.0.0 255.255.255.0 outside
Same kind of error if I try ASDM
TCP out 10.101.0.88:60920 in 192.168.2.3:443 idle 0:00:04 Bytes 18 FLAGS - Bs
