06-07-2001 11:41 AM - edited 03-08-2019 08:20 PM
I am having a problem setting CSPM 2.3i to communicate, via the Postoffice protocol on the standard port, to a sensor every 30 seconds. Do you set the heartbeat interval on CPSM, under the Policy Distribution Point tab, to accomplish this? Do you have to modify anything on the sensor?
Right now the heartbeat seems to occur every 5 seconds.
06-08-2001 10:09 AM
You may select the sensor in CSPM. Click the Advanced tab and modify your settings in the "heartbeat" field to 30s. This should alleviate your timeout problem.
-Mun
IDS Product Manager
06-21-2001 06:54 AM
Any other suggestions? I already made the change you recommended.
