Problem to access Guest Server
wsilveira
I have a problem when i try access guest server, I saw on the console that start the httpd daemon fail follow message:
[root@xxxx ~]# service httpd restart
Stopping httpd: [FAILED]
Starting httpd: [FAILED]
and at /var/log/http/error_log
[Wed Mar 30 19:03:33 2005] [notice] caught SIGTERM, shutting down
[Thu Mar 31 09:24:36 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Thu Mar 31 09:24:37 2005] [notice] Digest: generating secret for digest authentication ...
[Thu Mar 31 09:24:37 2005] [notice] Digest: done
[Thu Mar 31 09:24:37 2005] [notice] Apache/2.2.4 (Unix) DAV/2 PHP/5.1.6 mod_ssl/2.2.4 OpenSSL/0.9.8b configured -- resuming normal operations
[Thu Mar 31 11:29:29 2005] [error] [client 10.5.0.50] File does not exist: /guest/www/favicon.ico
[Thu Mar 31 11:29:35 2005] [error] [client 10.5.0.50] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:40:27 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:41:14 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:43:15 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:43:31 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:43:33 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:43:37 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:43:41 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:54:34 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:55:17 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:55:29 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 11:59:55 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 12:01:39 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 12:01:54 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 12:01:55 2005] [notice] caught SIGTERM, shutting down
[Wed Apr 06 12:03:59 2005] [notice] suEXEC mechanism enabled (wrapper: /usr/sbin/suexec)
[Wed Apr 06 12:03:59 2005] [notice] Digest: generating secret for digest authentication ...
[Wed Apr 06 12:03:59 2005] [notice] Digest: done
[Wed Apr 06 12:03:59 2005] [notice] Apache/2.2.4 (Unix) DAV/2 PHP/5.1.6 mod_ssl/2.2.4 OpenSSL/0.9.8b configured -- resuming normal operations
[Wed Apr 06 12:07:37 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 12:08:02 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Apr 06 12:08:08 2005] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:05:00 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:05:41 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:05:44 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:05:47 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:06:05 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
[Wed Mar 24 12:06:09 2010] [error] [client 10.5.0.52] File does not exist: /guest/www/favicon.ico
Faisal Sehbai
Level 7
Level 7
What's the history of this server? What version is it? Was it ever upgraded? Is it in production?
If not, you might want to consider re-imaging it. If it is in production and hung like this, open a TAC case so we can look at the logs more closely.
HTH,
Faisal
Faisal Sehbai
Level 7
Level 7
HTH,
Faisal
Faisai,
I solved this problem with re-imaging.
Wagner
