Problems with SA-VAM, 7200 and IOS 12.2(T)
peter.gehrmann
I actually have a Cisco 7200 series router for VPN tests.
I want to start with IOS 12.2(t) and a SA-VAM. The SA-VAM is not recognized by the router (Please have a look at the log). How can help.
IOS (tm) 7200 Software (C7200-IK9O3S-M), Version 12.2(8)T5, RELEASE SOFTWARE (f
c1)
cisco 7204VXR (NPE225) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 28341357
R527x CPU at 262Mhz, Implementation 40, Rev 10.0, 2048KB L2 Cache
4 slot VXR midplane, Version 2.6
00:00:05: %PA-2-UNDEFPA: Undefined Port Adaptor type 650 in bay 1
00:00:05: %PA-3-DEACTIVATED: port adapter in bay [1] powered off.
edadios
There is no code on 12.2T line that supports the VAM yet.
You would have to use 12.1.9E and higher in the 12.1E line code.
First of all, thank you for the information.
Is is response valid also for other routers like the 7100 series router?
Background: My company is a retailer with 600 store in Europe. We running actually a succesful test with 11 stores connected via Internet VPNs with our companies backbone. We want to migrate 200 stores next spring. Now we are looking for a VPN platform capable to run up 1000 tunnels and app. 30 Mbit/s and more 3DES throughput. The 12.2T high availability features and reverse route injection are a must.
It is basically for VAM. Support for 12.2T line is not yet out. So whichever router, the same applies for now. I suggest you contact you local marketing contact to push for release.
