As the error message says, the CA cert needs t obe installed in "Users and Identity Stores: Certificate Authorities".
Please make sure you enable the usage for TLS.
Also, if there are intermediate CAs, you need to install the certs of all the CAs, so that the ACS can trust it.
HTH,
Tiago
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
