07-03-2006 01:47 PM - edited 03-09-2019 03:29 PM
hello all,
i'm having trouble with upgrading from version 6.3 to ver 7.21 on a failover 535. i have no trouble loading the image in monitor mode but once the pix os is loaded i cannot ping the tftp server, or even the interface on the pix itself. i tried following the upgrade guide step by the step but still no luck. Interestingly in the "show run", u can see that i have an address on the interface i intend to use but in the "sh int" it says "IP address unassigned"
PIX Version 7.2(1)
hostname pixfirewall
enable password xxx
names
interface GigabitEthernet0
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet1
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0
shutdown
no nameif
no security-level
no ip address
interface Ethernet1
nameif inside
security-level 100
ip address 10.1.40.1 255.255.255.0
passwd xxxx
ftp mode passive
pager lines 24
mtu inside 1500
no failover
no asdm history enable
arp timeout 14400
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
service-policy global_policy global
prompt hostname context
Cryptochecksum:xxx
: end
and the "show interface"
Interface Ethernet1 "inside", is up, line protocol is up
Hardware is i82559, BW 100 Mbps
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
MAC address 000e.0c83.9934, MTU 1500
168 packets input, 11967 bytes, 0 no buffer
Received 134 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
105 L2 decode drops
0 packets output, 0 bytes, 0 underruns
0 babbles, 0 late collisions, 0 deferred
0 lost carrier, 0 no carrier
input queue (curr/max blocks): hardware (128/128) software (0/5)
output queue (curr/max blocks): hardware (0/0) software (0/0)
Traffic Statistics for "inside":
65 packets input, 3269 bytes
4 packets dropped
1 minute input rate 0 pkts/sec, 13 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 0 pkts/sec, 10 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute drop rate, 0 pkts/sec
anybody has any idea about this?
thanks in advance.
07-04-2006 01:28 PM
what's your IP?
check PIX has a route to you.
how does its ARP cache look?
07-25-2006 12:59 AM
Hi frmoody,
I've the same problem with a pix515E Ver7.0. After a manual configuration everything was fine. Then I saved the config and did a reboot and now the IP-Address is not assigned to the interface. Have you already found a solution for this? Please let me know. I find it strange that it worked before...
fw5(config)# sh run int eth1
interface Ethernet1
nameif inside
security-level 100
ip address 149.3.253.254 255.255.0.0
fw5(config)# sh int eth1
MAC address 0017.0e14.1103, MTU 1500
106624 packets input, 7284142 bytes, 0 no buffer
Received 106624 broadcasts, 0 runts, 0 giants
0 L2 decode drops
input queue (curr/max blocks): hardware (128/128) software (0/37)
106624 packets input, 5781238 bytes
21633 packets dropped
fw5(config)# sh ip add
System IP Addresses:
Interface Name IP address Subnet mask Method
Ethernet0 outside 192.168.12.2 255.255.255.0 CONFIG
Ethernet1 inside 149.3.253.254 255.255.0.0 CONFIG
Current IP Addresses:
fw5(config)#
thanks in advance.
