09-13-2005 12:44 PM - edited 03-09-2019 12:25 PM
I finally got a 1720 routing packets between my lan and internet. Now I need to prevent any access to the cisco router. Any ideas on where to start?
My setup:
internet
isp
cisco 204.246.200.XX1
Linux Firewall/NAT 208.49.53.XX1
IOS (tm) C1700 Software (C1700-Y-M), Version 12.3(1a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 06-Jun-03 20:01 by dchih
Router#show running-config
Building configuration...
Current configuration : 946 bytes
version 12.3
hostname Router
memory-size iomem 25
ip subnet-zero
no ip source-route
ip icmp rate-limit unreachable 1000
no ip domain lookup
interface FastEthernet0
ip address 204.246.200.XX1 255.255.255.252
no ip proxy-arp
speed auto
interface Serial0
ip unnumbered FastEthernet0
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
no fair-queue
ip classless
ip route 0.0.0.0 0.0.0.0 204.246.200.XXX
ip route 208.49.53.XX1 255.255.255.240 FastEthernet0
ip route 208.51.56.XX1 255.255.255.248 FastEthernet0
no ip http server
no cdp run
line con 0
line aux 0
line vty 0 4
no scheduler allocate
end
09-13-2005 06:41 PM
Start with these:
http://www.cisco.com/warp/public/707/21.html
http://www.cisco.com/warp/public/707/newsflash.html
In addition, if you don't want anyone to be able to access the router from outside then your input ACL on the Serial interface should look something like the following:
access-list 100 deny icmp any any redirect
access-list 100 deny ip 127.0.0.0 0.255.255.255 any
access-list 100 deny ip 224.0.0.0 31.255.255.255 any
access-list 100 deny ip host 0.0.0.0 any
access-list 100 deny ip 10.0.0.0 0.255.255.255 any
access-list 100 deny ip 192.168.0.0 0.0.255.255 any
access-list 100 deny ip 172.16.0.0 0.15.255.255 any
access-list 100 deny tcp any host 204.246.200.XX1 eq telnet
access-list 100 deny tcp any host 204.246.200.XX1 eq ssh
access-list 100 permit ip any any
This incorporates the ACL's from the above two URL's, plus denies any telnet/SSH attempt at your router specifically.
09-14-2005 07:19 AM
After looking at the links you provided, would this work better to block anybody trying to connect to the cisco router?
interface Serial 0
ip access-group 100 in
access-list 100 deny ip any host 204.246.200.XX1
09-15-2005 08:31 AM
Bernard
I would be very cautious with that access list. Every access list ends with an implicit deny any any. So if you do not have some statements that permit some traffic you will find that nothing goes through the router interface. Also be aware that if you attempt to protect access to the router with access lists on interfaces that it can get pretty complex. To the extent that the router has multiple interfaces, you will need to specify each of these interfaces in the access list. Also if you deny ip any with your router
interfaces as destination you will also prevent any ping from working, or any traceroute from the router, or lots of other things that you may need.
I believe that you should start by carefully evaluating what your requirements really are. If you want to prevent any remote access, the simple solution is to configure this:
line vty 0 4
no exec
This will prevent ANY remote access to the router.
But that may be more severe than you really want. If you want some remote access from inside addresses and not from outside I suggest that your primary approach should be to configure access-class on the vty ports. access-class uses standard access lists to define who can access the router remotely. It is a much better approach than attempting to create access lists on interfaces. It would look somewhat like this:
line vty 0 4
access-class 10 in
access-list 10 permit
Rick
