Reaper overriding refCnt and TunnelCnt deleting SA
eriqjohnson
I'm using your figure 12-3 example on page 320 in a lab and get this error : Reaper overriding refCnt and TunnelCnt deleting SA trying to ping from Pix2 to SIte 1
I can't ping from Site 1 to Site 2. I can ping from C1 to Site 2.
Eric
b.speltz
Level 4
Level 4
Hard to say from this. You will have to investigate further, with the use of logs. Here are some brief instructions on what to do to enable this.
On the VPN Client:
On the VPN client, enable the Log Viewer. Click the Filter button and rightclick on IKE, IPSEC and AUTH one at a time and increase the log level to high.
On the VPN Concentrator
Using URL: http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/rel3_5_1/config/events.htm
INCREASE the "severity to log" of IKE,IKEDBG,AUTH and AUTHDBG event classesto "1-13"
