Remote client restrict access to network scanner
jlwomeld
On my VPN 3000 I am having problems restricting a range of IP address that are network scanner. I have created a network list with the range of address. I also created a rule for in/out traffic using the network list in the rule. I created a filter and the action is drop. We I VPN in I can get to everything on the internal network I just want this client to be able to get to the network scanners. I am stuck at this point. Any help is needed. Thanks
smalkeric
Level 6
Level 6
There a few things to check on the concentrator. Is the SNMP server enabled under Configuration | System | Management Protocols | SNMP? What is the default action default action to take when no rules on this filter apply? It should be Drop.
You can find out out under Configuration | Policy Management | Traffic Management | Filters , select Public filter and Modify .
Thanks for resp, I did fig this out, I forgot to add the rules to my filter.
