REMOTE DESKOP GATEWAY IN DMZ
ktzouv001
I am new in the community.
I have Cisco ASA 5510 and i have DMZ,INSIDE,OUTSIDE Interface.
I am sure that yu have hear lot of times tis question but before write i have try lot of things without n result.
I have an Remote Desktop Gateway in DMZ.
My problem is that when i try to connect froM Outside i see that connected but can't authenticate the user and ask all the time for password.
What else must configure to connect users from outside through RDG.
Philip D'Ath
Does the firewall say it is blocking anything?
Hi Philip,
Finally i found that the problem is with RPC – RPC Dynamic ports. Unfortunately i must configure a specific range for the RPC – RPC Dynamic Ports.
Do you know any other solution that can use Remote Desktop Gateway in DMZ without need to do this configuration because i must change registry settings that i don't prefer.
