09-11-200809:32 AM - last edited on 03-25-201905:13 PM by ciscomoderator
Can anyone recommend a replacement for a VPN Cisco 3005 that will also tie into Active Directory so that users of the VPN can change their AD accounts while using the VPN. Total of <100 users.
The Cisco ASA 5510 should suit your needs. The ASA is the replacement for the 300 series concentrators. You should be fine integrating active directory using ACS server with the ASA.
