Requesting DHCP advice
jkrawczyk
Hi everyone;
I need a recommendation please;
My following connection is a inside router, pix 525, then an external router terminating my serial ISP line. Between my firewall and my outside router, I have a L2 switch.
I need to setup a DHCP service so that visitors can pickup DHCP address. What is available to me is dhcpd on the pix, or open a hole into my inside network so that these visitors can obtain this IP address from my inside DHCP Windows server.
Advice please? Can anyone send me a bogus example of a working config?
Kind Regards
Jeff
paddyxdoyle
Level 6
Level 6
When you mention visitors, are they at remote sites or are they inside your network?
If they are remote users are you trying to create a remote access VPN?
Paddy
Hi Paddy;
Visitors, meaning onsite. These visitors will plug into a layer 2 switch that I have between my pix and the outside internet router. My goal is to give these users access to the Internet, but I will be responsible for assigning these folks public IP addresses. I don't care what these users do once connected.
Jeff
Hi Jeff,
Is it not possible to make ext. rtr as DHCP server for public Ips..?
MS
