Restricted to Failover license
tholmes
Hello
I need to convert 2 PIX Firewalls, one from restricted to unrestricted and the other from restricted to failover, then have them run as a pair, does anyone know if PIX-515-SW-FO is the correct product to use on the secondary?
Many thanks Tony
3 Accepted Solutions
Patrick Iseli
Level 7
Level 7
Contact your Cisco Reseller or sent an email to:
mailto:licensing@cisco.com
Ask for:
Cisco PIX 515 Firewall License & License Upgrades
1.) Fail-Over
- Product Number = PIX-515-SW-FO
- PIX 515/515E Fail-Over software license.
2.)Restricted to Unrestricted
- Product Number: PIX-515-SW-R-UR=
- PIX 515/515E Restricted to Unrestricted software license upgrade. Includes PIX-515-MEM-32 to upgrade base chassis from 32 Mbytes to 64 Mbytes.
you can install these on your PIX and activate the unrestricted version on the PIX..
See:Cisco PIX® Firewall Licensing
http://cisco.com/en/US/products/sw/secursw/ps2120/products_data_sheet09186a00800b0d85.html#wp52661
sincerely
Patrick
jeffrey.chong
Not only software have to be one unrestricted and fo,
the hardware must be the same, ram, ports, model ...etc
tyagivijay
Hello Tony ,
you need 1 FO bundel & 1 UR bundel .
One should be UR(unrestricted Bundel) & other can be FO Bundel or UR bundel.
Vijay Tyagi
10 Replies 10
Patrick Iseli
Level 7
Level 7
Ask for:
1.) Fail-Over
sincerely
Patrick
Many thanks Patrick
Regards Tony
Do u have exact same models of firewall.(If not then the failover feature wont work) the primary firewall and the failove firewall must exactly be identical twins and must have exact same IOS.
If u wanna convert the failover to primary u unit then u must have the key for regualar (i guess restricted) firewall for that device and then change the key and it will work.
Let me know if it helps.
Many thanks for your response
Zaheer_Assariya
One more thing .. to convert the restricted firewall license to unrestricted ....u have to pay the cisco the fee and they will give u the key to convert it to unrestrited. Same goes for failover. But remember the firewall must be identical twins for example 535 vs 535 with same IOS.
yes mate, they've paid for the upgrade and FO license
PIX-515-SW-FO
Cheers Tony
jeffrey.chong
many thanks for your help
Regards Tony
tyagivijay
Hello Tony ,
Vijay Tyagi
Best Regards Tony
