03-18-2002 10:02 PM - edited 03-08-2019 10:06 PM
I am eval'ing LMS for my company. I have generated inventory using ANI and synchronised with RME. I can see my 3500XL switches in Hardware Reports within System - All Catalysts, and I can see all my 2950T switches within Hardware Reports - Generic SNMP.
When I try and perform Configuration Mmanagement using NetConfig, no matter what I pick in the Select Device Catagory ( IOS, Catalyst or FastSwitch ) phase, when I browse devices in the Select Devices phase, I can only see the 3500XL. The 2950T's do not appear in any combination of selections as choices.
The 3500XL appears as IOS - All Catalysts.
The 3500XL's are running Cat IOS ver 12.0(5.2)XU, and the 2950T's are running Cat IOS 12.0(5.3)WC(1).
Can anyone please offer me some advice as to what part of my inventory / configuration is incorrect. All devices were discovered using CDP.
03-19-2002 09:06 AM
2950T is not listed as a supported device in Campus Manager 3.1/RME 3.3's Supported device list:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/camp_mgr/sup_dev/dev_spt.htm and
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/cw2000e/e_3_x/3_3/e3_3.htm
03-25-2002 07:16 PM
Thank you for your reply.
If this is the case, then why are the following comments made in the document http://www.cisco.com/warp/public/cc/pd/si/casi/ca2950/prodlit/c29ie_ds.htm
1) Manageable through CiscoWorks network management software on a per-port and per-switch basis providing a common management interface for Cisco routers, switches and hubs.
2) In addition to the Cisco CMS Software, Catalyst 2950 switches are manageable via CiscoWorks 2000 products, which provide full enterprise-class network management.
As I have stated, I can inventory and syslog the 2950T's, but not manage them with RME. If in fact RME does not currently support these devices, when will support be provided in the future?
03-26-2002 11:34 AM
CV 5.3 supports 2950. Futuer versions of RME may have the support for this.
