RSA key less than 2048 bits for X.509 certificate chain certificate
at@ps
Hey all,
I have a Synopsis from a VA on my catalyst switch as below:
" The X.509 certificate chain used by this service contains certificates with RSA keys shorter than 2048 bits."
and the suggested mitigation is as follows:
Replace the certificate in the chain with the RSA key less than 2048 bits in length with a longer key, and reissue any certificates signed by the old certificate.
I've been searching for hours, but what I found is related to changing the Diffie Hellman key size!!
MY question is:
How can I change the modulus size?
Please help!
The certificate is basically a signed container that holds a public key and some information. This key should be at least 2048 bits nowadays. They are asking that you generate a new key pair of appropriate length and use this to request a new certificate from your CA. Diffie-Hellman is not related to this message.
thanks for your reply.
Could you give me some resources to implement this?
The command to generate new RSA keys of 2048 bits length is as follows:
crypto key generate rsa modulus 2048
Hope this helps.
Regards, LG
*** Please Rate All Helpful Responses ***
When the VA complains about the CA chain, I expect that you will have to ask your CA administrators. If it is the device certificate, the process starts with the command above, but you also have to configure a trustpoint and let it interact with your CA. Better get someone to do it for you.
