04-15-2004 04:40 AM - edited 03-09-2019 07:04 AM
Hello together,
maybe you can help me!
Installation VMS 2.2, VMS 2.2 Update 1, MC_IDS 1.2.3,
all IDS_xxxx processes are running.
I want to get an E-Mail if signatures are matching the severity level high, using the Perl script "emailalert.pl"!
The events are coming only from one IDS-Sensor 4235.
I can execute the script manually using the command line. But during normal work it seems that the script won't be activated because no temporary file "idsalert.txt" is created.
Also i tried the actual patches, don't help!
Any Ideas!
Thanks and best regards
Alexander
04-24-2004 06:49 AM
Any update on this ?
04-26-2004 11:24 PM
i have uninstalled the MC IDS 123 and reinstalled, imported the sensor. Then it works!
I know that it is not a good solution, but i had no better idea.
Alexander
