SNMP Security risks
bjenner
Community Member
What is the potential security risks with SNMP on a PIX firewall? To what extent could somebody access, monitor or reconfigure a PIX firewall assuming they knew the community string?
Bill
jsivulka
Level 10
Level 10
See "Using SNMP with the Cisco Secure PIX Firewall". This document will give you the information you are looking for.
http://www.cisco.com/warp/public/110/pixsnmp.html
mostiguy
Level 11
Level 11
Cisco PIX's SNMP support is completely read only.
There is not a ton of information available thru snmp on a pix - interface MIBs, cpu temperature and utilization (IIRC), connection count. Allowing someone to snmpwalk a pix would allow them to learn the ip addresses of each interface, so that is undesirable, but on the whole, the pix exposes not a ton of stuff, and that which is does is RO. Still, you would like to restrict access by ip address and robust community string on ideally from a secured subnet.
