split-tunneling - accessing internet problem
mborgul
Community Member
I'm trying to configure vpn split-tunneling. Now I have access to central office network via dial-up connection, but I can't browse internet sites.
I use cisco secure vpn client ver 3.6.6(a) and C1750 as a vpn server.
I have configured vpn connection in following way(conf regarding vpn below)
access-list wyjscie_VPN permit ip 10.0.0.0 255.255.255.0 192.168.99.0 255.255.255.0
global (outside) 1 interface
nat (inside) 0 access-list wyjscie_VPN
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
route outside 0.0.0.0 0.0.0.0 x.x.x.x
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10 set transform-set ESP-3DES-MD5
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local bigpool outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup vpn3000-all address-pool bigpool
vpngroup vpn3000-all dns-server 194.204.169.9
vpngroup vpn3000-all split-tunnel wyjscie_VPN
vpngroup vpn3000-all idle-time 1800
Could anyone tell me where is the problem?
Thanks in advance
Michal Borgul
mostiguy
Level 11
Level 11
Who runs the DNS server 194.204.169.9?
At my office, i dropped to a cmd prompt, did a nslookup, set server to that ip, and got timeouts. If that server restricts functionality to certain IP address spaces, that would explain your problem - if I configured my desktop here to use that as a DNS server, I would have effectively no "internet access" as name resolution would be broken.
You could try removing the vpngroup... dns... command, as without it, I believe vpn clients should then continue to use whatever their existing dns settings are
mborgul
Community Member
it's address of dns server our national provider. I have tried with other name servers...but it doesn't helped.
I have removed command regarding dns server configuration. And problem still exists.
In vpn client I can see (in statistics) that following networks are secured:
network subnet
0.0.0.0 0.0.0.0
x.x.x.x 255.255.255.255
Where x.x.x.x is my pix outside interface.
Is that correct? Especially my question is about first network. Generally it means last resort route.
Michal
