Showing results forĀ
Search instead forĀ
Did you mean:Ā
Software update problem
joseramada
Hi.
I've made a software upgrade of a CVPN3000 from release 4.1 to 4.7 to get the WebVPN feature. The update succeeded but I couldn“t access the concentrator since then. No more HTTPS access I get the error "You might not have permission to view this directory or page using the credentials you supplied". I tried to enter through the console (like explained in the guide) but no success either. The hyperterminal windows says that the connection is made but nothing appears. If I connect to a switch or router I get the management window immediatly.
What's happening?
Ramada
sachinraja
Level 9
Level 9
Hello Ramada,
Try reverting back the IOS to 4.1....
Try the following procedure and restore the VPN box.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2284/products_configuration_example09186a008014c1ba.shtml
Try just reloading the box before doing this change and see if u are able to access.
Hope this helps.. rate replies if found useful...
Raj
Hi Raj.
I've managed to get to the console using a cat5 network cable. I've confirmed (again) that the http/https is running on the VPN concentrator and the access list is correct. After that I can now connect through HTTPS management. I suppose the HTTPS management option changed to disabled after the new image was installed. Strange thing....
Thanks anyway
Ramada
