Split-Tunnel
abdul.kokumo
I have a PIX 515 with three network interface (outside, inside and dmz). Also the remote users use VPN Client 3.5 to get to the inside network and internet. Split Tunnel is configure and is working. The VPN client can get to the Inside network fine, use VNC and other applications but cannot use any service on the Dmz network except ping. Meaning cannot open the web server on the Dmz but can ping it. Cannot use VNC etc to the DMZ but can use it to the Inside. Is my configuration mising something or the PIX can only split trafic to inside and internet.
6 Replies 6
abdul.kokumo
I got the fix. The access-list name or number use for VPN from the Client to the inside and dmz must be different. Also the access-list applied to the VPN group for Split-Tunnel must be the same with the inside. Example below:
access-list 150 permit ip "inside network" "vpn client pool"
access-list 160 permit ip "dmz network" "vpn client pool"
nat (inside) 0 access-list 150
nat (dmz) 0 access-list 160
vpngroup "name" split-tunnel 150
The above solution is not the fix. I can ping the host on the DMZ but I cannot establish any tcp or udp connection. I thought I got the fix but I am wrong. I need urgent input. S.O.S.
Actually , you are very close to find the fix:
combining 150 and 160 into one access-list and apply to inside and dmz interface as well as the split-tunnel access-list.
The fix is as below:
access-list 150 permit ip "dmz network" "vpn client pool"
nat (dmz) 0 access-list 150
Best Regards,
This is the configuration I had. I can ping the host IP on the DMZ but I cannot open any TCP/UDP session like WWW, VNC or TFTP. I can do this with host on the INSIDE. The only service from the VPN Cleint to the DMZ is ICMP Ping.
Would you kindly check the access-list applied to the DMZ interface ?
If you can ping the host in DMZ, that means something block the traffic in the DMZ interface.
If you like, you can upload the PIX config and we have a check for you.
Best Regards,
Thanks. Below is the config. I think the problem has to do with "Asymmetric Routing" which is not supported on the PIX. When the Clients initiate a VPN connection the Client is virtualy put on the Inside network so when the PIX Firewall detects the same connection arriving on a perimeter interface, the PIX Firewall has more than one path to a destination. The PIX thinks an attacker is attempting to append packets from one connection to another as a way to break into the PIX Firewall and drops the connection.
PIX Version 6.1(1)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 dmz security50
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 1720
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
fixup protocol domain 53
names
access-list 101 permit ip 1.1.2.0 255.255.255.0 172.16.2.0 255.255.255.0
access-list 101 permit ip 1.1.1.0 255.255.255.0 172.16.2.0 255.255.255.0
access-list acl_inbound permit tcp any host 64.8.42.101 eq www
access-list acl_inbound permit udp any host 64.8.42.98 eq tftp
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
mtu outside 1500
mtu inside 1500
mtu dmz 1500
ip address outside 64.8.42.100 255.255.255.240
ip address inside 1.1.2.100 255.255.255.0
ip address dmz 1.1.1.100 255.255.255.0
ip local pool remote 172.16.2.1-172.16.2.254
global (outside) 2 64.8.42.109
nat (inside) 0 access-list 101
nat (inside) 2 1.1.2.0 255.255.255.0 0 0
nat (dmz) 0 access-list 101
static (inside,dmz) 1.1.2.0 1.1.2.0 netmask 255.255.255.0 0 0
static (dmz,outside) 64.8.42.98 1.1.1.98 netmask 255.255.255.255 0 0
static (dmz,outside) 64.8.42.101 1.1.1.101 netmask 255.255.255.255 0 0
access-group acl_inbound in interface outside
route outside 0.0.0.0 0.0.0.0 64.8.42.97 1
crypto ipsec transform-set remoteset esp-des esp-md5-hmac
crypto dynamic-map remote 2 set transform-set remoteset
crypto map mymap 2 ipsec-isakmp dynamic remote
crypto map mymap client configuration address initiate
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address 0.0.0.0 netmask 0.0.0.0
isakmp identity address
isakmp client configuration address-pool local remote outside
isakmp policy 8 authentication pre-share
isakmp policy 8 encryption des
isakmp policy 8 hash md5
isakmp policy 8 group 2
isakmp policy 8 lifetime 86400
vpngroup xxx address-pool remote
vpngroup xxx dns-server
vpngroup xxx wins-server
vpngroup xxx default-domain
vpngroup xxx split-tunnel 101
vpngroup xxx idle-time 2100
vpngroup xxx password ********
