04-16-2003 10:09 AM - edited 03-09-2019 02:56 AM
My company was bought out and we are combining networks instead using our scheme of IP we are going to use theirs. I am sure that this has been asked before but I could not find it.
How do you clear the present config and start over?
04-16-2003 11:08 AM
If you are using a PIX firewall then the write erase command will clear your flash memory. Afterwards type in reload to reload the router with no configuration.
Hope this helps
Mike
04-16-2003 02:15 PM
Thanks, about 20 seconds after I wrote this I found the command I needed.
"clear config" in config mode. make sure that you are on a console!
