Static Nating Help ?
manish-young
Level 3
Level 3
Dear All,
I have Pix 506 with 6.3 Version. Public IP is assigned on Outside Interface. Need to Nat internal server to public IP assigned on Outside interface, So far no luck through PDM. ANY Advise ??
jackko
Level 11
Level 11
not very familiar with the pdm. below is the sample codes if you would like to try cli.
e.g.
static (inside,outside) tcp interface 80 80 netmask 255.255.255.255
access-list inbound permit tcp any interface outside eq 80
access-group inbound in interface outside
with the above same, inbound http access is permitted to the web server.
brad
Frequent Visitor
Frequent Visitor
The above example is port forwarding. I suspect this is what manish-young is looking for.You can also use a NAT configuration.
static (inside,outside) outside inside
or
