Strange CPPr Behaviour
babanonyme
Hi All,
I try to play with CPPr and I came with the following to drop all packets to closed ports except RIP:
class-map type port-filter match-all closed
match  closed-ports
class-map type port-filter match-any validPorts
match  port udp 520
policy-map type port-filter PortPMAP
class validPorts
    log
class closed
   drop
control-plane host
service-policy type port-filter input PortPMAP
and that works fine, now, if I remove the log action of validPorts, I stop receiving RIP updates (checked with debug ip RIP) and my routes eventually become removed on routing table.
Per this link:
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6642/prod_white_paper0900aecd804fa16a.html
policy-map copp-policy
class coppclass-bgp
< no operation specified since this class has unrestricted access to route processor >
So I would expect that even with no log my traffic should be permitted.
Is this a bug, or did I missed something ?
I am running on
R3(config)#do sh ver  | i IO
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 15.1(3)T2, RELEASE SOFTWARE (fc1)
Collin Clark
I think you're running into this problem because RIP uses brodcasts. Try enabling RIPv2 and specifiying a neighbor. That will enable RIP to use multicast. This would need to be done on each router.
Hope it helps.
Hi Collin,
I already have RIPv2. When I have the log action, I see packets to 224.0.0.9, it's just for some reason if I do not put a log action packets looks droppped.
As a workaround I can do
match  closed-ports
match not udp 520
But that is strange... Maybe i'll try a differnet IOS version if I have some time.
I can try it in the lab tonight too.
