TCP Reset-O - Teardown tcp conncetion
ramprasad13
Dec 23 2013 20:04:31: %FWSM-6-302013: Built outbound TCP connection 146543498379530235 for inside:192.168.5.250/4831 (172.168.25.1/4380) to P_DMZ:172.168.25.13/139 (172.168.25.13/139)
Dec 23 2013 20:04:31: %FWSM-6-302013: Built outbound TCP connection 146543850566848420 for inside:10.2.37.24/4830 (172.168.25.1/4379) to P_DMZ:172.168.25.13/445 (172.168.25.13/445)
Dec 23 2013 20:04:31: %FWSM-6-302013: Built outbound TCP connection 146546388892520514 for inside:10.2.37.24/4832 (172.168.25.1/4381) to P_DMZ:172.168.25.13/139 (172.168.25.13/139)
Dec 23 2013 20:04:31: %FWSM-6-302014: Teardown TCP connection 146546388892520514 for inside:10.2.37.24/4832 to P_DMZ:172.168.25.13/139 duration 0:00:00 bytes 190 TCP Reset-I
Dec 23 2013 20:04:31: %FWSM-6-302014: Teardown TCP connection 146529170368630773 for inside:10.2.37.176/2943 to P_DMZ:172.168.25.13/445 duration 0:00:04 bytes 8159 TCP Reset-O
Dec 23 2013 12:07:30: %FWSM-6-305012: Teardown dynamic tcp translation from inside:112.31.1.37/2924 to Photo_DMZ:172.168.25.1/60861 duration 0:00:30
Dec 23 2013 12:07:30: %FWSM-6-305012: Teardown dynamic tcp translation from inside:112.31.1.37/2926 to Photo_DMZ:172.168.25.1/60869 duration 0:00:30
some user not able to connect server  ip address 172.168.25.13
server ip add 172.168.25.13
user from 10.X,192.X,15.X
Continues message we are getting in FWSM and some user from 10.X,192.X,15.X are able to connect this server some user not able to .
If changes required in windows server what changes need to done if changes to required firewall FWSM to changes need to be done.
0 Replies 0
