Problem with port-security and MAC addresses learning disabled?
Javier .A
Is there any problem, or incompatibility, if you configure port-security on 'n' ports that belong to X vlan and also disable mac-address-table learning over that vlan?
Has anyone references, links or pdfs about this issue?
Thank you very much,
Best Regards.
Hi Javier,
As I showed above the combination is valid. I didn't put any static entries in port-security but any entries learned via port-security will be shown as static when issuing show mac address-table. All dynamic learning is off.
I'm not sure what kind of security issue you are trying to solve but the configuration is valid.
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib
CCIE #37149
CCDE #20160011
daniel.dib
Level 7
Level 7
What is the reason for disabling MAC learning?
Seems to be working from what I can see:
Switch#sh run int f0/1
Building configuration...
Current configuration : 119 bytes
interface FastEthernet0/1
switchport mode access
switchport port-security maximum 2
Switch#show mac add vlan 1 | i Fa
   1    0012.00f0.b9a0    STATIC      Fa0/1
Switch#show port-security
Secure Port  MaxSecureAddr  CurrentAddr  SecurityViolation  Security Action
                (Count)       (Count)          (Count)
      Fa0/1              2            1                  0         Shutdown
Total Addresses in System (excluding one mac per port)     : 0
Max Addresses limit in System (excluding one mac per port) : 6144
Switch#show port-security interface fa0/1
Port Security              : Enabled
Port Status                : Secure-up
Violation Mode             : Shutdown
Aging Time                 : 0 mins
Aging Type                 : Absolute
SecureStatic Address Aging : Disabled
Maximum MAC Addresses      : 2
Total MAC Addresses        : 1
Configured MAC Addresses   : 0
Sticky MAC Addresses       : 0
Last Source Address:Vlan   : 0012.00f0.b9a0:1
Security Violation Count   : 0
There is another device connected to Fa0/3.
Switch#sh run int fa0/3
Current configuration : 57 bytes
interface FastEthernet0/3
R3#ping 10.0.0.1
Sending 5, 100-byte ICMP Echos to 10.0.0.1, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 1/2/4 ms
Traffic flows, traffic is flooded to R3 because no MAC address was learned there when port-security was not used.
If we implement blocking of unknown unicast traffic can't flow to R3.
Switch(config)#int f0/3
Switch(config-if)#switchport block unicast
R3#ping 10.0.0.1
Success rate is 0 percent (0/5)
So yes, MAC address learning can be disabled even if port-security is used. However traffic will be flooded to all ports in the VLAN. This could be blocked by implementing blocking of unknown unicast as shown above.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Hello daniel.dib,
For security reasons it's seeking to disable dynamic learning entries on configuring:
(config) no mac-address-table learning vlan
and after that to configure port-security on 'n' interfaces belong to .
I think this configuration should work right although the only entries that will be showing on mac-table would be those statically configured with port-security, isn't it?
Thank you.
Hi Javier,
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
