telnet to UDP port
aksher
any tool to telnet to udp port?
zerozerotito
You cannot telnetto UDP port...Because UDP is a connectionless protocol and Telnet needs a connection so thats why it uses TCP...
Pls Rate all Posts
m.sir
Level 7
Level 7
If you want to see if host has some "alive" udp port you can use some port scanner with UDP support
try this
http://www.bluebitter.de/portscn2.htm
M.
